Author Topic: 3dB 20W and 20dB 20W attenuators in series. What is the max power?  (Read 2186 times)
Offline LM21Topic starter
I hope the subject says it, but I try to cheat and get 40W (23dB) attenuator,  or at least higher power. For example,  if I have a 3dB 20W attenuator, does it mean that it can dissipate 20W and pass another 20W. Is it even  possible to say this with various manufacturers.
Offline jonpaul
Re: 3dB 20W and 20dB 20W attenuators in series. What is the max power?
« Reply #1 on: March 05, 2024, 03:59:04 pm »
each attn is rated 20W MAX thru.
You WILL NOT get higher power thru with series.
Got to mfg specs.
We use Minicircuits, see spec.
Jon
Jean-Paul  the Internet Dinosaur
The following users thanked this post: samofab, ch_scr, pdenisowski, LM21
Offline pdenisowski
  • Product Management Engineer, Rohde & Schwarz
    • Test and Measurement Fundamentals Playlist on the R&S YouTube channel
« Reply #2 on: March 05, 2024, 07:02:14 pm »
There's a reason why I don't try to make one of the big ones by connecting together a lot of the small ones :)
Test and Measurement Fundamentals video series on the Rohde & Schwarz YouTube channel:  https://www.youtube.com/playlist?list=PLKxVoO5jUTlvsVtDcqrVn0ybqBVlLj2z8
Free online test and measurement fundamentals courses from Rohde & Schwarz:  https://tinyurl.com/mv7a4vb6
« Reply #3 on: March 05, 2024, 07:14:32 pm »
"You WILL NOT get higher power thru with series. "
I  checked  Minicircuits data. Minicircuit like you said,  is a reliable supplier. But they did not answer my question. i don't doubt your word but I would like to read more about it. Or is it just ohms law in attenuators.
Offline ahbushnell
« Reply #4 on: March 05, 2024, 11:25:58 pm »
To minimize stress on attenuators you use the lowest first.
Assume all matched terminations
3dB  => .5 in power
So half the power will go ot the 3db and the other half down the line.  So 3db gests 10 watts
10 watts goes into the second 20 db attenuator.
20db => .01 gain
10 watts goes to 0.1 watts.
The 10 db attenuator gets 9.9 watts.
If you start with the 20 watts it will get a large chunk of the power.  (20-.2)=19.8 watts.
Very little into the second 3 dB.
Andy
Online radiolistener
  • Country: ua
« Reply #5 on: March 06, 2024, 12:22:22 am »
No. The input power is limited with your first attenuator rating. If your first attenuator is rated for 20W, then you can put max 20W on the input.
There is no way to cheat with low power attenuators. The only way to put 40W is to put first attenuator rated for at least 40W.
You can use more powerful attenuators. For example, you can use 100W attenuator for 40W signal.That is okay.
Offline rfdave#gmail.com
« Reply #6 on: March 06, 2024, 01:12:42 am »
think about it this way. a 20W 3dB attenuator has a maximum input of 20W. If you put 40W into that, then you'll damage it, that's too much power.
However, at the output of that 3 dB attenuator, there's now 10 W. If you have a 10W attenuator, then you can use it safely there, and stack up attenuation that way.
The following users thanked this post: ahbushnell
Offline fourfathom
« Reply #7 on: March 06, 2024, 02:33:48 am »
But remember when stacking attenuators that a fair amount of heat can be transferred by the connectors.  The first attenuator will be heating the second beyond ambient, etc.  So you may want to de-rate the attenuators a bit.  But really, you always want to de-rate an attenuator -- they get hot!
We'll search out every place a sick, twisted, solitary misfit might run to! -- I'll start with Radio Shack.
Offline jonpaul
« Reply #8 on: March 06, 2024, 02:45:30 am »
get passive R pad calcul, T pad or Pi pad.
https://www.pasternack.com/t-calculator-pi-attn.aspx
https://www.rfcafe.com/references/calculators/attenuator-calculator.htm
Setup Zin=Zout = 50
ATN = 3db, 20 db.
Calc resistors
Use Ohms law, draw/sim ckt with Vin = eqv 20W on 50 Ohms.
Current (I) = 0.632 e (A)
Voltage (V) = 31.62  (V)
OR calc https://www.calculator.net/ohms-law-calculator.html?v=&vunit=volt&c=&cunit=ampere&r=50&runit=ohm&p=20&punit=watt&x=Calculate
Get every internal R rating ..
Should be 10 min on an envelope by hand faster if you sim
j
« Reply #9 on: March 06, 2024, 06:49:52 am »
So max input power of 20W attenuator is 20W. 10W becomes heat and the other 10W comes out of it. I should do the calculations, for example with Minicircuits PI configuration. It is not hard.
Other problem is that are those attenuators symmetrical, what is high power input, and what is output.
Offline vk6zgo
« Reply #10 on: March 06, 2024, 11:33:37 am »
Ignoring the second attenuator for a moment & just using the 3dB one, if you are starting with 40 Watts, & you put a 3dB attenuator in line, a matched load will see 20W, & 20W will be dissipated in the attenuator, which is its maximum rating.
If you now replace the load with a 20dB attenuator of the same power rating & place the load at the output of that second attenuator, this will yield 200mW into a matched load.
The 20dB attenuator is dissipating 19.8 W which is very close to its maximum rating.
In this case, both attenuators are very close to being "cooked". (don't ask how I know!! :-[)
Online ejeffrey
« Reply #11 on: March 06, 2024, 02:43:51 pm »
That is definitely correct with respect to what the data sheet says.  However the construction of the 20W 3 dB attenuator (10 watts dissipation) sure looks a lot like the 20 W / 20 dB attenuator.  (19.8 watt dissipation). It's certainly possible that the internals are different enough that the ratings are correct, but its also possible (even likely?) that the entire range including the 3 dB attenuator are designed for 20 watts thermal.  I think this is likely in order to account for increased dissipation when the load is mismatched or open circuit.
If all that is true, technically you could run 40 watts input power to the 3 dB attenuator as long as you always have a matched load such as another attenuator on the output.  But this is definitely operating outside the specifications.
Offline PA0PBZ
« Reply #12 on: March 06, 2024, 02:45:59 pm »
I disagree, the power rating of the attenuator is the maximum input power, not the dissipated power. Maybe that's why you cooked yours?
Offline fourfathom
« Reply #13 on: March 06, 2024, 04:05:01 pm »
Yes!  Don't think of the attenuator rating as if it's a resistor.
And depending on who is selling them, those small aliexpress attenuators have ratings all over the place for the exact same part.  Plan on derating those by half, and still expect them to be uncomfortably hot at that power level.
Offline PA0PBZ
« Reply #14 on: March 06, 2024, 04:35:07 pm »
Also the rating decreases with increasing temperature, did someone say runaway?
Offline Hamelec
« Reply #15 on: March 06, 2024, 07:52:09 pm »
I would like to drill an 8mm hole - is it possible to use a 5mm and a 3mm drill bit for this?  8) :-DD
  • Country: ua
« Reply #16 on: March 06, 2024, 09:09:39 pm »
As I know, attenuators are rated with max input power, not dissipation power. So if you push 40W to a 20W/3 dB attenuator, it can be burned out despite the fact that dissipation power is just 20W.
It is very easy to burn out attenuator, I have several burned attenuators. So, be careful.
« Last Edit: March 06, 2024, 09:12:56 pm by radiolistener »
Offline CaptDon
  • Country: is
« Reply #17 on: March 06, 2024, 09:41:03 pm »
Read the specs for the exact attenuator you have. It may be 'Max Input Power' rated or it may be 'Max Dissipation' rated. You need to know!!!! I have some of each type. Kay Electronics, EMCO, HP etc.
« Reply #18 on: March 06, 2024, 09:58:02 pm »
Easy to beliewe, but they are so cheap.
  • Country: ua
« Reply #19 on: March 06, 2024, 10:19:36 pm »
As the saying goes, "Cheap fish - crappy yushka"
« Last Edit: March 06, 2024, 10:21:27 pm by radiolistener »
Offline vk6zgo
« Reply #20 on: March 07, 2024, 05:31:30 am »
No, it was because of putting the 20w attenuator first & the 40W attenuator second---what happens when your load has the wrong sex connector on it, & in a moment of "brain fog", I reversed them instead of using a second "N" adaptor.
You are right, of course, as the attenuator is a network, so the first shunt/series resistor combination is hanging directly across the higher power input.
I normally used much higher rated attenuators than the power I was dealing with.
Offline Marsupilami
« Reply #21 on: March 07, 2024, 05:45:55 pm »
Everything that needed to be said has been said, but it's better with pics.
If you think about max input power in dBm that makes chain derating much much easier.
Offline CaptDon
  • Country: is
« Reply #22 on: March 08, 2024, 02:43:07 pm »
I can say for a fact that with the larger 50 watt and up attenuators they are dissipation rated!!! A 500 watt 3dB unit can and will max out at 1KW input with a properly matched load on the output. That very same physical size attenuator when purchased in the 20dB or 40dB model can and will max out at around 480 watts input and the 40dB model can be used as a dummy load with very little V.S.W.R. reflected to the input side with nothing connected to the output side although I keep a 10 watt 50 ohm 'N' connector dummy load to use as a terminator in those cases. Handy rule of thumb is if you are approaching 80% of the rated dissipation of your attenuator based on dissipation and NOT input power you probably need the next higher wattage rated model. I have never ruined an attenuator and we ran up to 50KW water cooled units and dummy loads with water cooling, air cooling or vapor phase cooling up to 4 megawatts. Cooling systems were based on customer specs, duty cycle and available finances vs. 'dependability'. As always, go cheap and it will surely burn up!!!
Offline vk6zgo
« Reply #23 on: March 09, 2024, 12:29:06 am »
That is the sort of thing I was used to, & used the dissipation rating as that was how I remember using them, but it does seem intuitive that smaller ones are rated by the input power they can handle due to the fact that they are networks, so, assumed I remembered incorrectly.
Offline fourfathom
« Reply #24 on: March 09, 2024, 02:39:45 am »
I suppose it depends on the manufacturer.  Here is a Mini-Circuits 100W 20dB attenuator, rated at 100W input on the male port, and 20W input power on the female port:
https://www.minicircuits.com/pdfs/BW-20N100W+.pdf
Lesson: check the specs!
