Thanks again, this has all been extremely helpful.
The application is for a preamp integrated into a filter assembly. It will be used in front of a wideband SDR receiver such as the RX888 or the KiwiSDR. With the typical antenna system and receiver location, the signals at the lower end of the HF range can be quite strong, and at the upped end additional anti-aliasing is often needed (especially when the SDR ADC sample-rate is reduced (down to perhaps 60 MHz). So the structure is an input high-pass RLC "shelf" filter that starts at about -20 dB under 1 MHz, then transitions to -1dB above 20 MHz. This feeds the preamp, which drives a four-section elliptic low-pass filter that essentially brick-walls above 30 MHz. I've got boards in service now that just contain the filters, and they work very well. The amplifier is something new. The SDRs tend to be a bit deaf at the high end of the range, and the 1dB or so filter loss doesn't help. People are using external preamps, so this new design should simplify things.
I believe that in this application noise figure is less critical than dynamic range, but it's obviously going to be a compromise.
I built a second amplifier using a 2.2 Ohm emitter resistor, and a 560 Ohm feedback resistor. This simulates out at about 43 Ohms input R, which is OK. I can still tweak those values, but I used the parts I had on hand. The measured gain at 10 MHz is +19 dB, measured IP3 is about +25 dBm, and the 1dB compression point is -8dBm. The -3dB frequency is 182 MHz,
Now I get to solder down the filter components and see how it all plays together. That elliptic filter Z gets squirrely above the cutoff frequency, so we shall see how the amplifier reacts. With resistive terminations the amp by itself shows no oscillations, at least not up to 1 GHz, I will check higher as well. The board has a moderately tight surface-mount layout, but the components are 0603 or bigger and are not placed too tightly. It;s a 2-layer board.
