Author Topic: Icom 7300 power switch  (Read 671 times)
Offline GargoyleTopic starter
« on: June 21, 2024, 03:49:46 am »
Hello. My 7300 had a hard time turning on this morning and would not turn off. Has anyone replaced there switch? Easy, difficult?
Offline Solder_Junkie
Re: Icom 7300 power switch
« Reply #1 on: June 21, 2024, 07:07:02 am »
You can leave the 7300 turned on and switch off the power supply without a problem. That is how Icom radios with an Ethernet connection (9700, 7610, etc) are turned on/off when used remotely. Crude but effective.
SJ
Offline Teledog
« Reply #2 on: June 25, 2024, 04:07:59 am »
Email Icom.
Used to work for them, ..they may be nice & send you a replacement switch (I would)  :)
Service manual is online: http://logqslbyc.com/qsl/icom/IC-7300_Servicio.pdf
G'Luck! :-+
