I don't know what I want/need. I don't have the skills to make that choice.
The layout is super simple so I have some flexibility.
I have a full ground plane on inner 1, the RF module and the SMA connector are on top layer.
I tried with a microstrip configuration and JLCPCB gives me a 11.55th trace width for JLC7628 stackup.
Saturn PCB gives me 12.45th with no plating thickness ( there is soldermask on this trace ).
Then I tried with coplanar ware configuration and with 55th of conductor gap between top layer ground plane and the RF trace, Saturn PCB gives me 14.95th
I find that both results are in the same order of magnitude but I was told that the trace must be much larger.
I'm looking for information so I don't look too stupid
Thank you for your time
