Author Topic: SSMCX cable needed  (Read 133 times)
Offline w2hx
SSMCX cable needed
« on: May 18, 2020, 11:42:20 pm »
Hello friends,
I am not completely sure if this is the right/best forum for me to post my question. Ok, real long shot, here goes.
I am in need of a cable a few inches long at least with a right-angle ssmcx connector on one end and something more "normal" on the other end. Dont care what, but like sma/3.5 for example. It is just for troubleshooting, so I just need to mate with the other end and cable quality is unimportant.
Here is the picture of the kind of cable I need. The side on the ruler is this SSMCX connector (I believe, please correct me if I am wrong!)
https://w2hx.com/x/Harris/RF-310M-HH/Repair%20Pix/0518201908a.jpg
As for the gender, I am not sure what it is called. The cable connector fits within the connector on the board that I am trying to mate with. Is it male? However the center of this cable connector has a tiny socket for a tiny pin to go into. So is it female? Maybe female?
here is a picture of what I need to mate with on the pcb
https://w2hx.com/x/Harris/RF-310M-HH/Repair%20Pix/0518202023a.jpg
I am located in the USA and will gladly pay for the cable and postage from anywhere in the world.  Any help greatly appreciated!  Also interested if anyone can suggest another forum for me to ask for help would also be appreciated.
Thank you
73 Eugene W2HX
« Last Edit: May 19, 2020, 12:28:30 am by w2hx »
Offline Gribo
Re: SSMCX cable needed
« Reply #1 on: May 21, 2020, 07:27:46 pm »
Digikey carries some molex PNs and cable assemblies.
https://www.digikey.com/en/product-highlight/m/molex/ssmcx-coaxial-rf-connectors
Measure the outer diameter, it might not be SMMCX.
I am available for freelance work.
Offline w2hx
« Reply #2 on: May 21, 2020, 07:29:27 pm »
Thank you for the reply. As it ends up, I think you are right. At this point I believe this is an SMP connector. I have ordered a mating cable so in a few days I will know for sure.
thank you!
73 Eugene W2HX
