Hello,
Analyzing the Yaesu FTDX-10 circuit, I discovered that the first mixer has an original design. Typically, mixers use transformers to separate the signal into antiphase components. But this mixer uses a splitter. In the appendix, I have added the original mixer circuit and its simplified version, more suitable for analysis.
I have not come across a similar mixer design. What advantages does it offer compared to using a conventional transformer at the input?
PS It is interesting that the Yaesu FTDX-101 transceiver uses a mixer with the same structure and splitter at the input, but it is active and instead of digital switch FTS3257, dual-gate field-effect transistors are used.
