Author Topic: corrugated magnetic shielding?  (Read 707 times)
Online coppercone2
« on: September 24, 2021, 08:03:57 pm »
Has anyone done any experiments with corrugated steel and wiring to see what the effect is on low frequency noise, as a way to shield a cable other then twisted pair for that frequency range?
I only have aluminum spiral, and it seems you need a helmholtz setup to test this, but has anyone seen the results of this type of shielding?
not a bad project to make the tester either.. I just want to see if there is a reason not to do so more then if there is a reason to do so
Offline radiolistener
  • Country: ua
Re: corrugated magnetic shielding?
« Reply #1 on: September 27, 2021, 10:23:50 pm »
it depends on what kind of field you're want to shield. You can calculate attenuation level from known material properties and distance from the source. The most complicated is a shielding from magnetic field within near field zone from a source.
