Author Topic: Software for CP168?  (Read 3913 times)
Offline Lord of nothingTopic starter
  • Country: at
Software for CP168?
« on: January 09, 2019, 05:50:51 pm »
Its this Radio: http://www.qziradio.com/en/pro-s.asp?class_id=72&id=1152&hits=156
( http://m.zastone.com/product/showproduct.php?lang=en&id=691#mettab5)
I got the Software from: https://www.maas-elektronik.com/MAAS-PT-130-D-PMR-446-Digital-Analog-Funkgeraet.2.html who is the "legal" PMR446 Variant.
The software dont work from there. The say the cant Connect.
Any idea where I can get the right Software?
Thanks
Made in Japan, destroyed in Sulz im Wienerwald.
Offline stj
The following users thanked this post: Lord of nothing
  • Country: at
Re: Software for CP168?
« Reply #2 on: January 10, 2019, 01:14:40 pm »
 :o wow thx!
I "know" the Site but I dont know that the have some download Link.  :-+
  • Country: at
« Reply #3 on: January 10, 2019, 02:04:08 pm »
dont work i get only the error message:
Offline stj
« Reply #4 on: January 10, 2019, 05:06:20 pm »
problem is still likely the usb driver.
so i'll ask again - what chip is it?
in windows hardware manager what is the VID/PID of the cable??
  • Country: at
« Reply #5 on: January 10, 2019, 06:03:19 pm »
I have 2x different. I see the Radio blinkink it seem that the software try to connect and the Radio dont replay the right way.
The German Company who sold it as legal PMR446 Radio told me there is no "hiden" program mode and I need to just connect them.
When I am back in my Sleeping Room I will look into the Info.
Offline stj
« Reply #6 on: January 10, 2019, 08:47:43 pm »
if it's like the baofeng stuff, make sure the volume is not set low - it supresses the data to the socket.
  • Country: at
« Reply #7 on: January 10, 2019, 09:36:02 pm »
USB\VID_067B&PID_2303&REV_0300
Prolific USB-to-Serial Comm Port (COM6)
USB\VID_067B&PID_2303\5&339BFA8E&0&8
good idea
When the try to connect I see/ hear the Radio is transmitting 2x so the set something to ground.
Maybe the internal connection is different between this radio and the other.
Offline stj
« Reply #8 on: January 11, 2019, 04:49:58 am »
try the usb driver from 409shop,
some newer drivers try to detect clone chips and then fuckup some way intentionally.
most radio sites have older drivers to get around this.
http://wp.brodzinski.net/hardware/fake-pl2303-how-to-install/
  • Country: at
« Reply #9 on: January 11, 2019, 06:17:14 am »
 :scared: Same error as before.
Offline stj
« Reply #10 on: January 11, 2019, 11:35:56 am »
time to do a test.
get a comms program like putty or miniterm,
connect the tx & rx pins together on the cable and see if you can send text out and back in again to the screen.
  • Country: at
« Reply #11 on: January 11, 2019, 02:15:07 pm »
 :-+ I see on the Radio that the "Transmission" Pin is set. I hear some noise in my speaker and the transmission led light up for a second.
Offline stj
« Reply #12 on: January 11, 2019, 03:57:11 pm »
shouldnt the speaker be disconnected by plugging the cable in??
  • Country: at
« Reply #13 on: January 11, 2019, 04:16:29 pm »
Sry I mean on the Desk.  :-[
  • Country: at
« Reply #14 on: January 11, 2019, 10:47:19 pm »
 :-\ How it should work:
But the connection dont work.  :palm:
Offline stj
« Reply #15 on: January 16, 2019, 07:53:15 pm »
  • Country: at
« Reply #16 on: January 17, 2019, 12:47:54 pm »
THX! Now it work! sadly... its only an Analogue Radio...
Iradio CP-168 -> Analouge
iradio DP-168 -> Digital
Offline stj
« Reply #17 on: January 17, 2019, 10:51:07 pm »
how expensive was it? DMR stuff is getting pretty reasonable now.
Offline stj
« Reply #19 on: January 18, 2019, 02:21:18 pm »
well it is pretty clear that it's analog at ali,
mascom i dont trust, there description does not add up.
what would be interesting, if chirp supports the radio you could try it on VHF (120-160MHz) and see what happens.
there is a small baofeng sold as UHF that seens to actually have dual-band hardware in it - this may be the same inside.
  • Country: at
« Reply #20 on: January 18, 2019, 03:43:46 pm »
I dont know which Radio I should set in chirp.
On Ali you can buy an VHF Version: https://de.aliexpress.com/item/IRADIO-CP-168-VHF-136-174MHz-2W-128CH-Compact-Portable-Two-way-Radio-with-Built-in/32693574824.html
Here we cant use for anything.
