well I broke the system down and all the parts went to other locations (cars), and the rpi is hooked up to something doing something right now so it will have to wait a while
The problem mine had was the "offset" in the middle of a spectrum created by what the program authors described as 'i/q imbalance offset'. The features that are added to the receiver programs (gnu radio, etc) designed to compensate for this offset did reduce it a little bit, but there was always a glaring line stuck in the middle of the spectrum, which irritated me. I tried to study this on forums for a little while but it seems that people have decided that its not really fixable. Other then it being slow to boot, it seemed OK, but I did not use it much. I thought about CM filters on the Pbanks and stuff but it seems that no matter what I do the project result will feel janky.
I thought to turn it into a laptop in a old box but its alot of work. It pisses me off too because the offset line is smack dab in the middle, even on a normal spectrum analyzer the useless left hand low frequency 'slope' is.. on the left hand. Whenever I looked at the SDR on my TV I wanted to get a rag and try to wipe off the line in the middle. As I understand it, its not a spectrum analyzer, and the real world uses don't care about it, but I wanted a 'fast signal scanner' to use in combination with other equipment, and quite frankly the IQ line ruined it visually. I just wanted it so I can see the spectrum in real time on the TV when I play with my tecsun radio... so the pi was just supposed to be a log/note book where I can write things and a spectrum viewer so I know how to setup the tecsun (just to look at the air band, since I was only able to get very spare audio from planes, I was trying to increase my probability of intercept, so I can squeeze something out of that little portable receiver on VHF in the living room)
https://www.reddit.com/r/RTLSDR/comments/93rewt/bought_a_plutosdr_and_i_have_a_static_line_in_the/its like if you took a sharpie and drew a fake sine wave on your oscilloscope thats always there!
