Author Topic: 44MHz Modulator  (Read 769 times)
Offline pinball!Topic starter
44MHz Modulator
« on: November 03, 2024, 07:11:18 pm »
I have the need for a 44MHz AM modulator to do some troubleshooting on TV IF stages. It has to be capable of modulating a full NTSC 6MHz signal at 44MHz. Unfortunately 44MHz is below what normal video modulators can handle. Any ideas? Providing an external carrier frequency is not a problem. I have HP modulators that are unable to go above a few kHz.
Edit: mhz to MHz
« Last Edit: November 03, 2024, 07:56:39 pm by pinball! »
Online Bud
Re: 44mhz Modulator
« Reply #1 on: November 03, 2024, 07:24:01 pm »
mhz is milli Hertz. Maybe this is the issue?
Re: 44mhz Modulator
« Reply #2 on: November 03, 2024, 07:55:26 pm »
It was meant as MHz. I can't say I've ever worked in the sub Hz range. Will edit for clarity
Offline dobsonr741
Re: 44MHz Modulator
« Reply #3 on: November 03, 2024, 08:18:25 pm »
Build or get a MC1374 based modulator. The usual channel 3 and 4 are above your target, detune it, it’s spec’s down to 30MHz. http://www.bitsavers.org/components/motorola/_appNotes/AN-0829_Application_Of_The_MC1374_TV_Modulator.pdf
