Electronics => RF, Microwave, Ham Radio => Topic started by: Yansi on January 28, 2018, 08:14:39 pm
Hi
playing with some interesting ideas to use the ADF4350 for, I run into an issue regarding the VCO range. I need to generate two frequencies: 2170MHz and 1085MHz, which is exactly a half of the first one. ADF4350 (4351) did look exact fit for the job, until I realized the bottom end of the VCO range is 2200MHz.
I need 2170, which is a 1.36% lower, than the specified minimum. Do you think it is possible or wise to use the ADF4350 slightly out of the range? I currently do not have any of these so I can't test it myself.
Do you know any other suitable single chip solution, that could output simultaneously these two frequencies? (2170MHz, 1085MHz) I did search a bit on the Analog Devices website, but could not find any suitable ones.
Thanks,
Y
as far as I know the ADF4350/1 has an output divider... you can thetefore set the VCO to twice the desired frequency and divide it by 2. Or by 4 for 1084 MHz
There is only one divider present on RFoutA, RFoutB is directly VCO output. There is no other divider available.
I need output of 2170 and 1085 MHz simultaneously from a single IC.
I do not want two ICs, if it can be done with only one.
According to fig 20 from the datasheet, it may be possible to operate at 2170MHz (red line marker), but guessing at reduced temperature range. After reading through the datasheet a bit, cold temperatures <0°C may become an obstacle.
(https://www.eevblog.com/forum/rf-microwave/adf4350-vco-range-question-2170mhz-possible/?action=dlattach;attach=390479;image)
sorry I didnt read your post carefully...
pushing the spec by 1-2% is probaby no problem as long as you stay around room temperature.
The actual VCO range is wider than the spec anyway to guarantee correct operation within the full temperature range (-40 to at least 85deg C).
Okay, I will try it, once I'll have a bit of time spared for it. It is one (of many) ideas for some future RF projects. If it'll work from at least 0°C and up, it will be good enough. :)
It is a kind of idea how to make a convertor for a 3400MHz HAM band - I am still trying to attack that one. More or less successfully.
3400MHz input, 1230MHz IF1, 145MHz IF2/output. (Hence LO1=2170, LO2=1085)
There are suitable SAW filters available for 1230MHz, input filter could be realized using microstrip.
