Tried once to make an "AM modulator", one of those low power MW TX for indoors. The result was awful: unstable frequency, distorted sound, too little power even when the receiver was sitting on the same bench, though still a great tinkering fun.
Conclusion was that next time to use a stable and well isolated oscillator.
Well, found recently a 4 pins IC from the TTL era, a 4.9152MHz square wave quartz oscillator (fabrication date 1983, 40 years ago
- and if that frequency seems arbitrary, it was to derive all the standard baud rates for serial communications over RS232 using nothing but TTL binary counters ICs). Anyway, clipped the alligators from a 5V supply directly to the pins of the osc IC, then probed its output with the oscilloscope. It was working just fine.
Now, 4.9152MHz is not a broadcast frequency for AM radio. In EU the MW broadcast band is allocated between 531-1602kHz, and has 9kHz spaced channels (or 526.5-1606.5kHz with 10kHz space between channels in USA). However, when dividing 4.9152MHz with an integer (easy to do with TTL counters), the divided F might coincide with one of the MW broadcast channels.
Fosc Divider Result Close to F error Error
(MHz) (N) (kHz) (kHz) (kHz) (% of the 9kHz channels spacing)
4.9152 3 1638.400 1638.000 0.400 4.4
4 1228.800 1233.000 -4.200 -46.7
5 983.040 981.000 2.040 22.7
6 819.200 819.000 0.200 2.2
7 702.171 702.000 0.171 1.9
8 614.400 612.000 2.400 26.7
9 546.133 549.000 -2.867 -31.9
Fosc divided by 3, or 6, or 7 will be very close to an ideal MW channel. I care about matching standard broadcasting frequency because more recent AM receivers no longer have continuous tuning, they can only tune in jumps of 9kHz.
Most tempting was to divide by 6 to get 819.2kHz as the AM carrier. There are ready made TTL counters with 6 (SN7492). Though, a counter with 6 will produce an asymmetric waveform. To get a symmetric 819kHz square wave, could have used a frequency doubler, then divide with 6 first, then again with 2 (using the same 7492). That would mean a few more TTL gates to make a frequency doubler, so yet another IC.
Then I've found this
unusual dividers idea from a PDF by Charles Wenzel, where a tuned LC is inserted in a typical D-type FF divider by 2, so to make it divide with ratios other than 2.
I've used same idea to make a divider by 3, together with 100pF, 100uH and a 54LS74 (in fact an M555TM2 i happen to already have), then used the remaining FF as a divider by 2. Tested the divider on a breadboard, and it was very stable. Tried it with LS, H, N and HCT types of 7474, and at Vcc between 2.5-5.3Vcc.
For the next stages, I've seen some schematics are using a single transistor as a class C common emitter RF amplifier, where the AM modulation is obtained by varying the collector voltage, while others are using a differential pair with a transformer output as RF amplifier, while the AM modulation is obtained by varying the tail current of the differential pair. Not sure which one to choose, and if 5V will be enough.
TL;DR got a quartz-stable carrier at 819.2kHz, square wave and with 50% duty factor, as Q and NQ from a TTL flip-flop.
What kind of modulator+RF amplifier schematic will fit well with this TTL carrier?
Is 5V enough for the RF amplifier (most I've seen are using 12V or more for the RF amplifier)?
