Author Topic: New 2400MHz Power Amplifier  (Read 607 times)
Offline oe7dbhnewTopic starter
  • Country: at
    • HiDes technik & OE7DBH
« on: October 30, 2024, 07:06:23 am »
Hello
Here is a new power amplifier with a lot of gain for transmitters with very low output power, such as the Adalm Pluto from Analog Devices.
Data:
Frequency range:                     2300...2450 MHz
Gain:                                          over 50 dB
Small signal gain:                    over 53 dB
Output Power CWmode :              up to 40 Watt
Bandwidth  -3dB :                     300 MHz     (  2200.....2500 MHz  )
Signal mode:                            all      ( with DVB reduced output power !, max. up to 8 Watt recommended   )
Operating voltage:                   24...30V               default 28 Volt        ( housing is minus )
Power consumption:               max. 4 Amps at full power
Input-Output connector:         SMA  female
RF monitor output:                  SMA female     (  -32dB  opposite output port  )
Input max. power:                    1mW           (  100mW is damage power  )
Amplifier size:                           15cm  x  10.5cm  x  2.2cm
Output protected by circulator from oversized antennas VSWR
Protected against incorrect voltage reversal
More info and testreport on:  https://oe7dbh.blogspot.com/2024/01/13cm-band-high-gain-power-amplifier.html
« Last Edit: November 12, 2024, 04:07:11 pm by oe7dbhnew »
Offline coppercone2
