Author Topic: Anyone tried this HF kit?  (Read 1176 times)
Offline retrev
« on: June 07, 2018, 05:04:44 am »
Saw this on eBay, it's cheap and you usually get what you pay for and all that. Wondering if anyone has one or has heard anything about them? Are they worth the money? I'm looking for something that will run reasonably off of batteries for QRP operation while hiking (which is partly why I want cheap...if it breaks, it's <$50 to replace it). Hoping it'll make descent regional or close DX contacts probably on 40m.
Offline CJay
  • M0UAW
Re: Anyone tried this HF kit?
« Reply #1 on: June 07, 2018, 06:02:35 am »
Ermm, which piece of kit?
M0UAW
Online hendorog
« Reply #2 on: June 07, 2018, 06:10:56 am »
What, can't you see it? Its the emperors new HF!
Offline vk3yedotcom
    • vk3ye dot com (radio articles and projects)
« Reply #3 on: June 12, 2018, 06:37:58 am »
There is only one sub $50 kit that could be considered high quality and with a good reputation for on-air use.
This is the QCX from QRP Labs.
https://www.qrp-labs.com/qcx.html
I've not built one but have heard good accounts from people who have.  It has many features that make it good for on-air work.
Eg single signal receiver, 5 watts output, frequency agile transmitter etc.
Much cheaper and widely on eBay is the Pixie.  They're fun to build and modify. Not so fun on air as contacts will  be hard.
It's very low power (about 0.5w), stuck on a single frequency and has a very broad receiver that may be overloaded by broadcast stations.
More detail at: http://home.alphalink.com.au/~parkerp/projects/projpixie.htm
There are some kits of intermediate price and complexity but again you want a good receiver, frequency agility and decent power output.
NEW!  Illustrated International Ham Radio Dictionary.  Over 1500 terms explained in a 180 page Kindle ebook.  $US $4.99 or equiv.  Just search 'Ham Radio Dictionary' on Amazon.
« Reply #4 on: June 12, 2018, 06:40:02 am »
Vote here for the QCX. Own one on 40m and very much like it. It’s currently being the poor thing copying my awful CW. When I keyed my call the other month when I had foundation license it came out M6TIT  :-DD
Offline CJay
  • M0UAW
« Reply #5 on: June 12, 2018, 08:57:43 am »
Mate of mine got given G7DUM or DIM, can't remember which but it caused him a fair bit of embarassment.
M0UAW
« Reply #6 on: June 12, 2018, 09:38:10 am »
Yeah never get auto assigned. Fortunately that was just me keying my old call which wasn’t M6TIT.
Hopefully M0 after tomorrow ;)
Offline CJay
  • M0UAW
« Reply #7 on: June 12, 2018, 10:32:09 pm »
Luck with that (not that I think luck's necessary)
M0UAW
Offline rhb
« Reply #8 on: June 13, 2018, 09:42:52 am »
I bought a pair of QCXs for 40 m.  Haven't built them yet, but without a license it's not a rush item.  But I looked at the design a good bit and was quite impressed.  I'm interested in developing  a low data rate protocol which will provide reliable low power communications over long distances.  Point to point RFmail.
The following users thanked this post: cncjerry
« Reply #9 on: June 13, 2018, 05:06:10 pm »
Design of the QCX is very nice. It’s a phasing receiver with class E PA and built in diagnostic and test gear. It does actually kick out 5W with a couple of BS170s which don’t even get warm. Was very surprised.  My only complaints are it comes with cheap shitty resistors and caps. There was a quality control problem with them for a bit. I built mine with higher quality parts and it worked straight up.
Offline Lord of nothing
  • Country: at
« Reply #10 on: June 14, 2018, 12:16:41 am »
Thats not far.  :scared:
Made in Japan, destroyed in Sulz im Wienerwald.
« Reply #12 on: June 14, 2018, 01:29:14 am »
In reply to someone who posted about there not being any schematics and then the post disappearing ;) ...
It's in the manual: https://www.qrp-labs.com/images/qcx/assembly3_A4.pdf and here https://www.qrp-labs.com/images/qcx/assembly3_A4.pdf
All the schematics are available.
Only thing that isn't is the uC firmware.
  • Country: at
« Reply #13 on: June 14, 2018, 01:41:56 am »
 :-[ why do you make an Double Post and not EDIT your Post?
« Reply #14 on: June 14, 2018, 01:43:29 am »
It wasn't a double post. I was replying to someone who asked where the schematics were. Then I did edit it and add the top line after the poster deleted it after probably finding them where I said. The edited post line at the bottom only appears if someone views the thread in the time between it being posted the first time and the edit.
Offline CJay
  • M0UAW
« Reply #15 on: June 14, 2018, 02:07:34 am »
I'm on the brink of pushing the buy button on a QCX, even closer now they don't have to travel thousands of miles from Japan, what sort of results are you seeing from it?
M0UAW
« Reply #16 on: June 14, 2018, 02:23:40 am »
Pretty good. It’s CW only. Got Canary Islands and Finland on a sotabeams squid pole with hacked up inverted V and 8xAA batteries. Receiver is as good as my FT-450D. Also acts as a WSPR beacon. The CW decoder is good enough for local practice without transmitting as well.
Don’t do what I did though and solder all the controls onto the board. Plan an enclosure up front and mount them on there.
My CW paddle cost a ton more than the damn thing.
Edit: fix stupid autocomplete failures. Also didn’t use an AMU with it. Cut antenna about right and winged it. Seems to be relatively SWR proof or I’m lucky :)
« Last Edit: June 14, 2018, 02:31:30 am by bd139 »
