Author Topic: aspect ratio of low frequency long ferrite antenna  (Read 1556 times)
Online coppercone2Topic starter
« on: January 10, 2025, 01:24:37 am »
So I know some basic guidelines for smaller ferrite rod inductors to leave some of the ends unwrapped (for like 2 inch long, they seem to use maybe 50-60% of the rod)
I have a real low frequency hi mu foot long rod now, and I am wondering if I should follow the same 50-60% rule or does it get different when the aspect ratio starts getting weird.
It is 1 inch x 12 inches.
I think it will be used somewhere about or way less then 1KHz
I previously glued some crap together from junk parts but that project never went anywhere
And I am also wondering if it should be one continuous winding, or if I should make multiple coils (like a coil gun design).
This kind of gets into it, but its much larger then mine
http://www.vlf.it/romero3/ics101.html
Is 12 inches long enough to justify winding it into sections to try to lower capacitance?
« Last Edit: January 10, 2025, 01:34:13 am by coppercone2 »
Re: aspect ratio of low frequency long ferrite antenna
« Reply #1 on: January 11, 2025, 05:17:30 pm »
And I even had thought about low capacitance windings, but it looks like it might be too difficult to predict what effect all these things could have.
« Reply #2 on: January 17, 2025, 09:45:07 am »
I think it might be a good idea to do this because it has minimum difficulty but it makes it easier to modify it, because for a receiver antenna, it hardly seems to matter if you solder each of the spools together, and its easier to wind. Assembly might be a tiny bit more tricky because it involves some fine splicing.
and it gives it the ability to pick the exact coil size by selecting the correct tap point.
« Last Edit: January 17, 2025, 09:47:45 am by coppercone2 »
