Hi
TL;DR: making a PCB band stop filter with SMT parts, please help me make an educated choice for my capacitors and inductors, dielectric type, and wire wound vs multilayerI am venturing into making a homemade 88-108MHz FM bandstop filter, with -30dB cut in this band. Just for fun and learning. This type of filter is to be used for reception, not transmission, so it is not expected to handle any serious power.
The goal is for this filter to have good performance until 1.5GHz.
After this frequencies, I expect parasitic phenomenon from the layout, and from the PCB material itself (FR4) to start becoming problematic.
Is this reasonable?
I used this website to calculate components :
https://rf-tools.com/lc-filter/
I routed a small PCB :
I calculated the trace width with a coplanar waveguide calculator with ground plane :
https://chemandy.com/calculators/coplanar-waveguide-with-ground-calculator.htm
I think this is not super critical anyway since most of the traces will not be actually that width due to the size of the components.
I am at the stage where I am selecting components.
For the capacitors, I plan to use regular SMT capacitors. Since the values are small,
I plan to go with NP0. But would X7R be problematic? Why?For the inductors however, I don't know what to do. Should I use wire-wound inductors, or multi-layer inductors?What are the selection criteria?
I expect the DC resistance is going to create losses, but that's about all I know, and I am not even sure it is true.
What about the self-resonance frequency, does it matter? What about the Q factor? Those things are a bit blurry to me and I would appreciate some pointers to make a more educated choice
Thanks!
