Disclaimer
Be gentle i'm not an EE (just a hobbyist), and have been "off the bands for many years
I'm installing my
first HF station/EFHW in the summerhouse
I have a FT991A , and a IC-706MKIIG (for playing around)
I would like to prepare for connecting the radios to some of my instruments.
And bought a "High Power" Attenuator + 4 small ones.
High powerA Bird Tenuline 8322 - 200W continuous -30dB Attenuator - N plugs
Liḱe this one -
https://www.martinrfsupply.com/bird-8322-rf-attenuator-200w-30db-used.aspxLow power4 x HuberShuner - 6610_SMA-50-1 SMA Attenuators.
Setup to be:
Radio (50dBm/100W) --> Tenuline (-30dB) --> (20dBm/100mW) --> 2 x HS -10dB --> (0dBm/1mW)
I am planning to be able to connect the output to :
Scope - Rigol + 50Ohm Through Terminators
Counter - HPAK & Philips
SA (HP 8594E) - I have a DC-Block on the SA Input.
I think i have to use 50Ohm +
AC coupling on the instruments , correct ??
Would it be better to get a SMA DC-Block , and always have it on the Attenuator line ??
I'm not planning on "full power all the time", when looking at stuff.
I might connect the Attenuator line to either my Palstar 2K Ant-Tuner (2'nd output) or to the MFJ 6-Chan Ant switch (MFJ 4716)
What would be preferable ?
I only have One Antenna , so i might leave out the MFJ for starters.
Do you have any advises against "beginner mistakes" , besides "don't bypass the attenuator line"
TIA
/Bingo
Ps:
The MFJ has Gas discharge "fuses", and can be set to ground antenna when no power is applied , that's actually the reason i bought it.
But i suppose the "Disconnect plugs physically, when leaving" still applies ??
I do have Alpha-Delta Arrestors on both HF (1KW) + VHF/UHF (200W) on the wall outside the shack , and 16mm ground cable going to 2 x 220cm ground rods.
