i am kinda new to vhf/uhf radio i have a baofeng UV-5R i got off ebay for 24usd (36nzd) free shipping took 7days to arrive to my house in new zealand
im looking for frequencies in auckland nz that people use or that i can use to listen to things
when i first got the radio i found a frequency 146.625 and people where talking on it im using the aerial it came with and this channel came in crystal clear
i listened for a couple of mins then i did some auto scanning to find other channels then maybe an hr latter i went back to 146.625 but don't hear anybody on it
i have tried it off and on every day and never get anything on that channel just a random static for maybe a split second ever couple of mins
thanks
if you have used this radio what are some good setting to use with it
146.625MHz is a Amateur Radio repeater in the "2m band".
There are others you could listen to, like:
145.775, 146.700, & 146.900 MHz.
It might also be worth looking at :
438.450, & 439.875 MHz in the "70cm" band.
Amateur Radio activity on repeaters is, unfortunately, just a shadow of its former self.
I'm not sure if the UV-5R you have can receive NZ UHF CB, but if it is programmed to do so, here is the info needed.
https://en.wikipedia.org/wiki/UHF_CBAnother possibility is that it might receive the aircraft bands from around 118MHz up, but they are in AM, & as far as I know, unlike a proper scanner receiver, the Baofeng doesn't include that mode as an option.
Listening is OK ----BUT please be aware that
you cannot legally transmit on any frequency with this radio, with the exception of those used by Amateur Radio,
which, however requires you to hold an Amateur Operator's Certificate of Proficiency, which, from the general tenor of the OP, you do not possess.It does not meet the standards for UHF CB, or any other other service,
Don't let anyone kid you!
Hams will report you, but if you transmit in the allocations of much more serious organisations like the army, aircraft control, cops or fire service, you will be "up before the beak" so fast, your head will still be spinning!
