Author Topic: Baofeng UV-5RM  (Read 1117 times)
Offline Randy222Topic starter
Baofeng UV-5RM
« on: September 24, 2024, 04:17:05 pm »
Got a new set of low cost radios to play with. Watched many online vid reviews and their testing. Most of those vids were from early days of the 5RM release. Not sure if anything has changed but here are my test results.
Test gear is tinySA Ultra v1.4-177 , and MFJ-842 power-swr needle meter
UV-5RM firmware v0.14 hardware v01
out-of-the-box testing, no chirp tweaks
SQL 3
Rx Sensitivity
AM 125.250MHz -116.2dbm
FM 137.250MHz -121.2dbm
FM 225.000MHz -123.2dbm
FM 430.250MHz -126.2dbm
Harmonics
VHF dirty-ugly
1.25M ok
UHF ok
Tx Power
Low
137.250MHZ 3w (*surges to 4w when PTT releases)
225.000MHz 2.5w
430.250MHz 2.5w
Middle
137.250MHZ 6w
225.000MHz 2.5w
430.250MHz 5.3w
High
137.250MHZ hi 10w
225.000MHz hi 5w
430.250MHz hi 11w
« Last Edit: September 24, 2024, 04:20:16 pm by Randy222 »
Offline pienari
Re: Baofeng UV-5RM
« Reply #1 on: September 25, 2024, 05:22:23 am »
Hi.
Have tested what was the tx freq low/up limits?.
Re: Baofeng UV-5RM
« Reply #2 on: September 25, 2024, 03:56:40 pm »
Hi.
Out of the box, just the lowest and highest frequency that I can key up?
These are just two points, other bands have restrictions on them (out of the box)
Lowest is 136.00000MHz
Highest is 519.99875MHz
« Last Edit: September 25, 2024, 03:58:17 pm by Randy222 »
Offline Wallace Gasiewicz
Re: Baofeng UV-5RM
« Reply #3 on: September 26, 2024, 12:00:58 am »
I have seen a few Baofeng radios on spectrum analyzers.   They all had terrible harmonics on 2 meter band.  Do not recall if I have seen other bands analyzed.
Re: Baofeng UV-5RM
« Reply #4 on: September 26, 2024, 02:57:30 pm »
There's a few vids that show 2m harmonics, but not the other bands, but they then mention "works ok on the other bands". Not sure why they just wouldn't show the other bands on the test gear.
