So just a different display, antenna and firmware?
Couldn't the original one detect it as it was?
The original one, if it was sitting right up next to the WiFi antennas, would "respond" with a reading but it would be completely meaningless. The AD8307 is only rated for DC to 500 MHz operation, ±1 dB linearity. So a calibrated power meter, such as the other ones I made, for WiFi bands would not be possible using this chip.
However, due to the AD8307's sensitivity in an
uncalibrated use, I found out it actually will respond to the 2.4 and 5 GHz band. But this is simply in an uncalibrated brute-force mode, right next to the WiFi antennas.
This response to the radiation in those two bands makes it's suitable for an indicator of emission activity. That's all this thing does. It shows you that your WiFi router is emitting RF, for a quick and dirty indication. There is no measurement or indicator on your router's case, nor in it's menu, that it's actually
emitting RF. There are only menu settings that show you the WiFi is supposedly turned on, but that doesn't mean the transmitter is actually working. Yes there are other ways to find that out but not as simple as this indicator, which sits right next to your router.
It doesn't measure power per se, it simply moves a bar graph up and down according to the RF detected which comes from the router. I have an auto-scale routine so the bar graph will go from the lowest power ever detected to the highest. It also re-scales every 60 seconds. If the router isn't emitting RF - the bar graph doesn't move at all.
