What sort of equipment are you using for your work up there? If you can't share exact setups that's fine, but I'm curious what's on your bench, so to speak.
Since Joel probably can't give us details very far beyond what is publicly available at the
Keysight mm-wave VNA site, allow me to speculate
They are working on a PNA-GTX with turbocharger. It does to 0-150 in under a second (GHz, of course), it has flame decals on the side, and the fans make "vrooom" noises that scare small animals. It finally does away with the three-box design (base VNA + mm controller + sample heads) in favor of just having small probe-size sampling heads that plug in to the main body. Different probes are available for different connectors / frequency ranges. To be announced in 2022, but none of our employers will be able to afford it until 2025.
Regarding janky home setups, though, I have to warn about expectations on SLA printers: accuracy and repeatability offer rude surprises coming from the world of machining, even janky home machining, where the usual rule is that you can do .010" without thinking, .001" with care and good technique, and .0001" by really dialing things in and sweating the details. Controlling for time, effort, and experience, cheap equipment sets you back half an accuracy class. 3D printing sets you back 1.5 accuracy classes.
You can get to within a few thou, but you'll have to bust your butt to make it happen. The exposure process grows/shrinks your part as a nonlinear function of geometry, temperature, humidity, resin type, batch of resin, how well mixed the resin is, etc. It's not a problem for printing D&D figurines, but it's a big problem for engineering... which explains the relative adoption of 3D printing to the two applications. For a while I used a chart to map hole sizes modeled vs actual (test part + pin gauges + patience) but after controlling so many variables and still seeing the plot hop around, I basically gave up. Every time I need accuracy on a print I resign myself to the necessity of iterating a few times or post-processing. It's like going back in time to before the interchangeable parts era. I've had 10x less trouble and better results compensating the deflection in a cheap cnc aliexpress router, and that's really saying something, because those aliexpress routers are themselves floppy garbage.
Oh, umm, and be sure to get a printer with linear rails. They are cheap these days. Everything bad I said applies to the ones with linear rails, but the ones without rails are even worse, because the build platform deflects due to stiction and makes the parts wavy in addition to the usual problems of over/underexposure, potato-chipping when drying, potato-chipping over time, elephant foots, and chicken skin.
Of course, if you're willing to relax expectations it's fine. If you just want to see a signal, what are a few dB, or even tens of dB? If you just want one working sample, a few iterations will absolutely get you there. Keep the rat-tail files handy, stay patient, and sneak up on those dimensions
One thing is for sure, it will be an adventure!
