Author Topic: China vacuums capacitors  (Read 954 times)
Offline jord4231Topic starter
« on: October 05, 2024, 10:54:20 pm »
Hi Just wondering if anyone has had any experience with these?
https://www.aliexpress.com/item/1005005910772893.html
Can't find anyone who's using them for radio related projects anywhere
I have built a balanced L matching unit and the Jennings vac cap I have its a bit too high at minimum C for my needs.
This one fits my requirements but I do wonder about it's mechanical longevity seals etc...
Cheers
Offline A.Z.
Re: China vacuums capacitors
« Reply #1 on: October 06, 2024, 06:11:35 am »
sorry, can't help with those, but the issue with vac caps is the sealing and "how long" they'll mantain it...
as for your Jennings min capacity, did you consider adding a switchable series doorknob to them to lower it when needed ?
Offline A.Z.
« Reply #2 on: October 06, 2024, 07:13:58 am »
alternatively, you may consider something like the attached, it can be configured as either a T or an L match using S1 and S2; the C3 and C4 fixed caps will have the same value as the max value of C1 and C2 and can be inserted in both configs (L or T) if/when needed; when in T config they'll help reducing losses
« Last Edit: October 06, 2024, 08:20:38 am by A.Z. »
The following users thanked this post: jord4231
« Reply #3 on: October 06, 2024, 10:02:05 am »
Thanks for the reply, I've experimented with series capacitors and while it works I think it will just be easier to get something that goes to around 10p rather than 50p I have linked a video for the project so far if you are interested.
https://youtu.be/PkCmKlOmHHU?si=NObs60NmXud0xFVb
Thanks again
Jordan
Offline A.Z.
« Reply #4 on: October 06, 2024, 10:21:26 am »
Offline A.Z.
« Reply #5 on: October 06, 2024, 01:18:11 pm »
