You meant those RF detector-based ones with cheap trace-based on cellphone IC-based directional coupler?
Still, getting the lower end (<1MHz, or even <10MHz) is not possible with exotic components.AD9361 starts from 70MHz, and cheap transmission line-based couplers usually have higher minimum frequency.
