Hm. I don't know that a general statement is appropriate; there are certainly applications, mass-market / industrial applications, that use them -- consider the hundreds of thousands of cell towers for example, equipped with quite tight diplexing filters, constructed as 20-odd element cavity filters; or similarly, commercial broadcast where bandwidth is shared on an antenna tower (the antenna is broad, individual transmitters narrow). In certain subsets that one may be familiar with, HAM radio for example, they're probably less common (lowpass most common AFAIK, being sufficient for impedance matching plus harmonic filtering purposes).
Though arguably, an antenna tuner is likely to have significant bandpass character so might still be considered a case, when one has a particularly ill-cut antenna for a given frequency of interest. Perhaps even more interesting as an example, as it becomes a conditional one, probably with poor stopband attenuation (i.e. response is a peak above a plateau, or with an upper asymptote (overall lowpass character), or having mode breakup (and thus additional, accidental passbands) at/beyond upper band edge due to strays in construction, but perhaps still useful as a tuner despite that.
It is most likely true that, while not every transmitter has a tight bandpass on its output, nearly every receiver does -- at least, where "tight" is relative to the image bands relevant at a given stage in the signal path, generally getting narrower as the signal is whittled down to final IF and detection.
