Author Topic: CMU200 50Watt with B95 Option?  (Read 598 times)
Offline chick0n
« on: July 23, 2021, 11:38:43 pm »
Hi
I own a cmu200 with option B95 (2nd generator). So I can only use the cmu with 2Watt input.
Option B95 is Sandwiched to the RF-Frontend Board. I opened the Frontend, and there is a 50Watt 17dB attenuator placed. Also there is place for another one.
Maybe it is possible to use the cmu with more than 2W input, when option B95 is disconnected/removed?
Maybe someone with a 50Watt unit could make pictures of his frontend. To compare and see if a 2nd attenuator is placed?
Offline xmo
Re: CMU200 50Watt with B95 Option?
« Reply #1 on: July 24, 2021, 04:28:07 am »
I think port RF1 has that attenuator so it can accept 50 watts whereas RF2 has no attenuator and can only handle 2 watts.
Option CMU-U99/B99 deletes the attenuator and makes the range of RF1 and RF2 be the same.
Offline chick0n
« Reply #2 on: July 24, 2021, 02:36:39 pm »
But every CMU200 with B95/96 has a Warning Sticker on Port RF1 and RF2 "Only 2 Watts". Mine too. Why?
Maybe its just the cooling... The 50Watt frontend has a fat heatsink installed, and B95 Option has none.
« Last Edit: July 24, 2021, 10:54:10 pm by chick0n »
Offline xmo
« Reply #3 on: July 25, 2021, 11:39:08 pm »
You are probably right about the heatsink.
I looked in the datasheet again and found that it does say you get reduced power with B95 so that accounts for the sticker.
[attach=1]
