I am not sure I see it.
I mean we have Eurocard as a standard for some things, but really a radio has quite a few subsystems that have very different needs in terms of form factor...
I have a rig done as a set of eurocards (Except for the input BPF, TX Power amp, Output LPF & power supply), but doing the whole thing as a set of identical modules is a huge ask (or a huge radio).
The PA for example often defines (and is defined by) the cooling and thermal design of the entire set, and things like LPF filter banks (and even RX BPFs) can be more then slightly on the large side.
Regards, Dan.
