With a proper transformer power supply, I would recommend changing to a 3-prong line cord.
The "ground" on the antenna connection is presumably to a primary on the RF input circuit, and should be connected to a proper ground, such as the ground stake.
Is that connection also connected internally to the chassis?
Edit: it took a while to download the manual, but both the RF primaries and the power supply are connected to the chassis.
