I feel like you should try to learn from it, whenever I hear about some usual " 'time period' stuff" its a sign that someone is trying to be fashionable in engineering, its a term that might apply to teenagers dating. Unless its the auto router.
To me it seems like a bit of a joke, because you have tube sockets, then the tube, which has a significant wire length on it, and a contact resistance. The tube leads are like kovar wire (kinda like stainless, aka heater wire), its not even copper, so there is that too, so the ground connection is ALOT different, just from the part. I am not sure the ground plane is gonna change things too much in this situation.
With high voltage things, not having a ground plane is kind of nice too, because there is less area for high voltage to try to get out of. I.e. depending on how a design can fail, you could have something stupid, like a energized ground plane bringing HV to a wire that happens to be touching the side of the PCB away from any parts. In that case, the lack of conductor is a good thing. Think about what can happen if there is a broken wire and a short, then suddenly that 'poor ground' is actually increasing safety.
