Hello guys,
I am an embedded software developer working on various different radio access technologies, like LTE and NR. After several years in this industry I decided to design my own piece of hardware. I wanted it to be related to RF and at the same point simple enough for a beginner.
Short theory of operation
1. I have no idea what input signal level expect. Furthermore, based on what I found, this may vary depending on a location and a direction of an antenna. Therefore I don't know how much gain I need. That is why I decided to use a digital potentiometer (U5) to set gain digitally. Furthermore, an operational amplifier (U4A) acts as a differential amplifier to set a virtual ground for the gain stage (U4B).
2. I want to use single voltage rail, therefore I must use an inverting configuration (at least this is my understanding).
3. I initially thought about designing DCF77 receiver, but then I learnt that there are other similar standards, like TDF for instance, operating in a similar frequency bands. Therefore finally I decided to create an analog fronted, which is capable of receiving a wideband signal between 50kHz - 200kHz (Butterworth filter, U4C and U4D), roughly speaking. Then I will do additional digital filtering to get my signal of interest.
My requirements and extra comments.
1. I am a software developer, not hardware designer. This means that I don't necessary know what I am doing
2. I haven't simulated my design yet. I want to know if I go in the right direction and what alternatives I have before I will put more time in this project.
3. I have no soldering equipment at home. Therefore I decided that I will get my project assembled by JLC PCB. This means, I was limited by component available in their library. On the other hand, I could use SMT component, which would be a pain in the neck to solder on my own.
4. I also didn't want to create my own component models. Therefore my second requirement was an availability of models in KiCAD or in Ultra Librarian.
5. I selected STM8L151K4T6 for a couple of reasons:
- it seems simply enough for beginning
- maybe at one day I decide to create a battery powered version of my project. Then low power micro would be useful.
- I have ST-Link available
6. I know that it is possible to receive DCF77 signal using a single diode and BJT, but I wanted something more interesting.
7. This project is made purely for fun.
I really curious to get your feedback. I will appreciate it.
Kind regards
