Author Topic: Open hardware near-field probes  (Read 2054 times)
Offline loxodesTopic starter
« on: June 12, 2016, 07:55:43 pm »
I've been lurking around these forums for a few weeks without posting, so I thought I'd share the first-order approximation of near field probes that I built recently: https://github.com/loxodes/em_probes/
https://github.com/loxodes/em_probes/tree/master/doc has coupling measurements of the probes above microstrip, They aren't perfect, but seem to work up to about 6 GHz. So far they've been helpful at probing a board that I didn't put enough test points on.. I've never used or seen proper near-field probes before, I welcome any feedback on how to improve the design.
If anyone wants to try replicating or modifying these, the layout assumes the OSH Park 4 layer stackup (http://docs.oshpark.com/services/four-layer/); y'all would need to modify the offset stripline for other stackups. The stripline was simulated with the MMTL open source 2.5D EM simulation software (https://sourceforge.net/projects/mmtl/files/tnt/1.2.2/), it could be helpful for tuning this to other board houses.
The h-field probe design was almost copied frominspired by "Study of Magnetic Probes Used in EMI Measurements" (http://www.apemc2015.org/Proceeding/papers/1570059913.pdf)
« Last Edit: June 12, 2016, 09:07:42 pm by loxodes »
The following users thanked this post: Pinkus, tymm
Offline daqq
  • Country: sk
    • My site
Re: Open hardware near-field probes
« Reply #1 on: June 12, 2016, 08:52:54 pm »
Nice work!
