Bob,they weren't surplus,the amplifiers & built-in exciter were a purpose-built order from the dear old People's Republic.
Apparently,they normally used the amps on 470MHz,as they were roughly tuned up for there.
The exciter had an "exciting" fault,too---the PLL would let go & slide up to a default frequency around 470MHz.
433MHz in Oz is within a Ham Band,but some low power devices are allowed in that band.
Our use of the frequency was tolerated by ACMA,as long as our screening didn't leak radiation above the level of those devices.
Hi
Oh, I very much understand that you got "not so great" stuff brand new from the factory.
That same fine factory with it's dubious approach to building amps probably kept on going. That or somebody else popped up with the same "just put it together and ship it" approach. Those amps will indeed show up on eBay. Even as "factory built" amps, they will still have the problems you describe when surplussed out. (assuming they lasted that long ...).
Bob
Yeah,Bob ,I got into this as a "help out from time to time" thing.
The original bloke fell ill,& myself & another Tech got "sucked into the maelstrom".
Tuning amps by sliding chip capacitors around with a toothpick whilst watching the swept response was something I hadn't done for about 20 years at the time (& I certainly hadn't missed it!
Googling,we found the test board setup for the devices used,& our boards looked like two of these stuck together,with splitters at the input,& combiners at the output.
These units were in turn paralleled,& the same done with the output of that,& so on.
It certainly looked like they thought putting the caps in the same place would make an amp with repeatable performance.
Maybe they grabbed a "Rent-A-EE",& as soon as he had done the initial work,chucked him back on the street!
Still,I guess if you could pick these things up cheap,& didn't mind tuning them,the individual amps would be quite useful.
