Just for clarification, the guy who made the claim was stating the twist of the inner conductor in a coaxial cable would have an impact of the flow of RF energy due to the right hand rotation of the EM field. Where if the rotation aligned with the EM field rotation with the direction of flow, this would alter the path loss. I agree, smells Audiofoolery, but it did get me to think about it some.
The EM field in a coaxial cable doesn't rotate in the right handed direction and that's also not what "right hand rule" means in electromagnetism.
The right hand rule or right handedness of EM fields in ordinary matter refers to the direction of propogation (Poynting vector) being the cross product of E and B. If E&M were left handed (as in some metamaterials for a narrow frequency band at least) the propogation would be in the opposite direction, -E x B. It doesn't have anything to do with fields rotating.
It is possible to have rotating fields. This is what you get with circular polarization in free space. Here both E and B rotate as the wave propagates through space. But there is no preferred direction, left and right circular polarization are equally possible and it has nothing to do with right handedness of E & M.
In any case, you don't get circular polarization in coax, or really any polarization. Coaxial cable is operated below the cutoff for the waveguide modes of the outer ground, only a single mode exists.
