Without some actual detail on the waveform and system, it's pretty near impossible to provide any insight. We don't know the load, the interconnect, what ever "very sharp" means, etc. Ringing will depend on the whole circuit, not just the FETs. There are all kinds of things that can ring, and they can all be excited by a "very sharp" edge.
But, it is likely that adding multiple FETs in series is going to add considerable inductance to the circuit, and this will most likely make ringing worse. Multiple FETs take more physical space, and worse, they are connected in series, which means the physical layout will tend to be longer and thinner. This will increase inductance.
How much inductance matters? That depends on the rest of the system. The higher the current, the more the inductance will matter. If you are switching 10A/ns, you will get a 10V spike for every nH. If it shows up primarily at your FET drain, maybe it's ok. If it shows up primarily between source and gate, you will be in trouble.
A rule of thumb for a bond wire in free air is about 1 nH/mm. This is worst case, typically.
If my numbers are not close to anything you are doing, that's because I have no idea what you are doing
Also, it would really help to know what voltage you are trying to get to. If it's under 200V, GaN devices are not that expensive (disclaimer: I work for a GaN device manufacturer). They get pricier above 200V, but it might still be cheaper in the long run. Although, I would be remiss if I did not mention that you can also get some crazy fast voltage rise turn-off edges with superjunction MOSFETs due to circuit inductance because their output capacitance is so non-linear.
Cheers,
John
