Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
RF, Microwave, Ham Radio
DIY RF Noise Bridge: Anyone use an SMD RF transformer with success?
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: DIY RF Noise Bridge: Anyone use an SMD RF transformer with success? (Read 988 times)
abitofhelp
Newbie
Country:
on:
December 10, 2024, 07:11:02 am »
Hello,
I am building an RF noise bridge (DC-100MHz (200-400, even better) to replace one that failed in my Palomar Engineers antenna tuner. I am using SMD components and have completed the implementation of the noise generator.
Now, I am designing the transformer stage between the generator and the Wheatstone bridge. I was planning on using an FT50-43 ferrite toroid, but I was curious whether any SMD RF transformers could be used. I found that several companies make SMD RF transformers, such as those I've listed below, but I don't know whether they would be good solutions for an RF noise bridge. There is no transmitting involved, so the requirements are simpler.
https://www.minicircuits.com/pdfs/TCM1-382WX+.pdf
https://productfinder.pulseelectronics.com/api/open/part-attachments/datasheet/cx2041nlt
>>> Assuming the correct taps on the SMD RF transformer, would one be a good substitute for a wrapped ferrite toroid?
Mike
K2MM
Last Edit: December 11, 2024, 05:14:36 am by abitofhelp
Logged
EggertEnjoyer123
Frequent Contributor
Country:
Re: DIY RF Noise Bridge: Anyone use an SMD RF transformer with success?
Reply #1 on:
December 11, 2024, 04:31:40 am »
Make sure you don't need a center tap before buying the Mini Circuits one.
A lot of the designs online have a center tapped transformer in the schematic.
Last Edit: December 11, 2024, 04:33:38 am by EggertEnjoyer123
Logged
abitofhelp
Newbie
Country:
Reply #2 on:
December 11, 2024, 05:14:08 am »
Good catch, @EggertEnjoyer123! Indeed, I do need that center tap.
Logged
abitofhelp
Newbie
Country:
Reply #3 on:
December 12, 2024, 12:15:05 am »
I am very interested in using a Mini-Circuits TC1-1T+ RF Transformer in my RF Noise Bridge. Based on the specifications, it seems like it would work well, but I am not a professional electrical engineer. I've attached an image showing the circuit and would appreciate your comments or suggestions about using the TC1-1T+.
https://www.minicircuits.com/WebStore/dashboard.html?model=TC1-1T%2B
Thank you for your help!
Mike
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
