I been trying to create a small pcb with an esp and expressLRS, for fun and practice.
And upon researching and creating my own pcb I'm mainly stuck at the antenna part.
I just found that there are similar products around using some interesting concepts.
Of course I know the "big" pcb trace antennas on all esp packages, but this trace antenna seem to be very small in comparison, I think its only around 5mm*3mm and still being for wifi.
I did some reasearch but could not found a similar design anywhere.
Maybe one of you guys can help to identify the design (hopefully not patented) so it can be replicated.
Original Product: GEPRC ELRS Nano SE Receiver (2.4HGhz)
As product size is only 12*10mm, the wifi antenna must be very small and different from regular esp pcb antennas
(I am not talking about the "SMD antenna", I really mean the pcb trace one)
This wifi antenna is mainly used for the initial setup/configuration/OTA, so no long ranges or big throughput required.
Cheers
