the issue is at the moment the missmatc kills caps on my chineese kit atu-100,i have 500v silver mica replacements but getting the antenna legs the same length would be a start,please tell me how i can measure there length as i originaly asked instead of going off on a tangent.73
You are at qrp power levels yeah? And you are blowing 1Kw rated caps in an L match tuner? Last I read you were using a manual Z match. If you go and read your other thread about ganging air caps I started to explain some fundamentals. You are going to have to do some work here to understand what is going on and then do a much better job of explaining your question, which I answered,
the length of the legs in your antenna do not matter and will never be electrically equal even if they are physically equal to the billionth of a millimeter (bold for emphasis) because all the obstructions they face being near metal adds capacitance, zig zagging adds inductance. Its a dogs breakfast and you might not like the answer, but that does not mean the answer is a tangent, it means you do not understand things. Electrical and physical length are two different things.
If you want to measure their length, pull them down and use a tape measure. You cant do a TDR because a single wire is not a transmission line. I get that you want to bring down the swr viewed at the tuner to about 50 ohms, so just cut 2cm off the end of each leg until you achieve that. Yes the ends, not the middle, not the feedpoint, the ends because if you cut at the feedpoint and then pull the wires to shorten them it will change the stray capacitance and inductance from the obstructions and throw everything off again. If you cant get to the ends then it sucks to be you, we cannot rewrite physics to suit your compromises.
I am going to assume you measure off 2 20m lengths of wire to make the elements and not just hung random lengths of wire in your roof. If you did that, then they are near enough to being physically equal and if you want to change the impedance seen by the antenna port on the tuner, you need to trim the ends, or lengthen them until you get 50 ohms at the tuner. Oh and one last thing, do not use the ATU-100 with a balanced feeder, its not designed to work that way, you need to use a balanced tuner.
