Author Topic: EMC Ward V070 VHF programming  (Read 5619 times)
Offline pienariTopic starter
« on: September 02, 2023, 03:12:29 pm »
Radios have been laying around my shack many years.
Now i have searched information for programming but found nothing.
I bought software few years ago but lost it somewhere because i dont know what kinda cable to use?.
There is com connector in back of the radio.
« Last Edit: September 22, 2023, 05:05:29 pm by pienari »
Re: EMC Ward V070 programming
« Reply #1 on: September 18, 2023, 04:25:09 pm »
After 5hrs searching old laptop hd i found it.
I found programming software and cable chematics.
« Reply #2 on: September 18, 2023, 07:44:07 pm »
Here is the cable chematics.
https://aijaa.com/pomXOC
Here is indentification pdf.
https://aijaa.com/qRYsUj
« Last Edit: September 18, 2023, 07:52:37 pm by pienari »
« Reply #3 on: September 20, 2023, 08:16:39 am »
I drawn a board for testing purpose.
https://aijaa.com/6FMOsu
I need to mill proto board with LPKF s64.
If that works i have to make smd parts and order few.
« Last Edit: September 26, 2023, 07:53:19 am by pienari »
Re: EMC Ward V070 VHF programming
« Reply #4 on: September 25, 2023, 12:11:58 pm »
https://aijaa.com/zORHG6
Board successfully milled.
Edit.
And i found 2 mistakes ..
« Last Edit: September 26, 2023, 07:25:58 am by pienari »
« Reply #5 on: October 01, 2023, 04:04:29 pm »
https://aijaa.com/vh48eC
Board is ready to test
« Reply #6 on: October 02, 2023, 09:13:38 am »
I measured from radio side DB9 connector and there is no +9v in pin1 ?.
+9.7v can be found in pin7 and -9.7v can be found in pin3
Now im a bit confused.
https://aijaa.com/1HLFaP
https://aijaa.com/QGDTWJ
« Last Edit: October 02, 2023, 09:23:46 am by pienari »
« Reply #7 on: October 02, 2023, 11:17:56 am »
I decided to disassemble the radio.
Inside I found the ST202 RS232 circuit.
https://aijaa.com/DFaRjv
ST202 ic pin8 2nd rx in, goes to DB9 pin8 = RS232 input
ST202 ic pin7 2nd tx out, goes to DB9 pin3 = RS232 output
ST202 ic pin13 1st rx in, goes to DB9 pin2 = RS232 input
ST202 ic pin14 1st tx out, goes to DB9 pin7 = RS232 output
« Last Edit: October 02, 2023, 01:55:30 pm by pienari »
« Reply #8 on: October 02, 2023, 08:08:01 pm »
Can anyone help with this?.
Any EMC owners aroud??.
« Reply #9 on: October 04, 2023, 05:16:47 pm »
I was playing with dos and i get software running.
https://aijaa.com/UDnRIE
1. How to read settings from radio ?.
2. If thats not possible how to make channel list.
« Last Edit: October 04, 2023, 05:20:37 pm by pienari »
Offline javier73
« Reply #10 on: April 01, 2025, 05:11:14 pm »
great job I wanted to ask you if you have the program for the radios - Wwstdy from rel 08 to rel 10 I would like to try to program them
hoping for your help regards
javier
« Reply #11 on: April 01, 2025, 05:48:44 pm »
I have lots of issues with this radio.
Still no cable.
Offline javier73
« Reply #12 on: April 01, 2025, 06:49:23 pm »
they are uncommon radios I tried to make an interface but I can't find the software program my radios have a firmware 09 they are ward 70mhz the program should be
emc ward- Wwstdy from rel 08 to rel 10 do you have it?
could you pass it to me? so I could see if my cable works
regards
javier
« Reply #13 on: April 02, 2025, 12:05:25 pm »
My software is for firmware 3 to 6.. i think.
Ward RT Programmer Ver 0.2
I bought this software from ebay about 10 years ago
I dont know it this correct software for my radios.
But what kind of cable you have made?. What pins it use?.
I think fw7+ need this software.
« Last Edit: April 02, 2025, 12:53:14 pm by pienari »
Offline javier73
« Reply #14 on: April 02, 2025, 09:38:02 pm »
yes the program should be that but in addition to the program you need a user and password the cable I wanted to try to build what you posted
so I could try can you send it?
thanks for the answers
regards javier
« Reply #15 on: April 03, 2025, 02:28:30 pm »
Maybe Ward radios are too rare now days.
That cable diagram came with the software is incorrect.
I donno what radio uses that.
I have tryed to look information but not found and i think you chould find it a bit better.
Le mie competenze in italiano sono un po' deboli.
« Reply #16 on: May 09, 2025, 12:37:45 pm »
www.iw1axr.eu/scarico/EMC%20suite.zip
I get 404 every time but my friend downloaded that file and now i can check if programming works.
« Last Edit: May 09, 2025, 01:31:42 pm by pienari »
