Author Topic: Testing the effects of releaving ground plane beneth a component  (Read 10208 times)
Online joeqsmithTopic starter
Re: Testing the effects of releaving ground plane beneth a component
« Reply #75 on: August 02, 2021, 06:22:19 pm »
Sweeping the gap from fully closed in 100 mil increments.   Gap is anchored to the left edge and opens towards the right as shown.   Slot=550.0 is closed.  The other settings are the same as before in AppCAD.
I wouldn't expect the wave shape to change as it does.
Hopefully this give you enough test cases to try.
« Reply #76 on: August 04, 2021, 09:49:39 pm »
Still using the symmetry mode but moving both ends of the gap to avoid the diagonals, I had hoped some of the data would make a little more sense.   I also thought it may reduce the memory requirements and speed up the simulation.
Offline neilhao
    • My Personal Website
« Reply #77 on: August 04, 2021, 10:05:57 pm »
Oh, I just did the similar work related SMA connector in UWB application. I have to use slot for eliminating the impedance mismatching between PCB trace and the SMA footprint.
My two cents:
https://uniteng.com/wiki/doku.php?id=uwb:evb#uwb_front-end_design
Notes about my technological project: https://uniteng.com
RF Store:
https://shop.uniteng.com
« Reply #78 on: August 06, 2021, 10:10:37 pm »
https://www.simberian.com/
Similar experiments with SIMBEOR.
Offline Marsupilami
« Reply #79 on: September 06, 2021, 07:19:07 am »
Did you come up with anything conclusive since?
Work went crazy in the past couple of weeks, I didn't have any time, but I'm still curious to see a comparison to measurements.
« Reply #80 on: September 06, 2021, 01:51:23 pm »
Sadly, I was never able to make any sense of it.   I suspect I am just asking too much out of the free tools.   It's a very interesting topic and it would be fun to experiment more with it.  Sadly, I was not able to find limited versions for the more modern tools and their costs far exceed my hobby budget.
