Author Topic: Experimenting with waveguides using the LiteVNA  (Read 181935 times)
0 Members and 25 Guests are viewing this topic.
Offline joeqsmithTopic starter
Re: Experimenting with waveguides using the LiteVNA
« Reply #500 on: July 11, 2024, 11:26:27 pm »
Part 5, a touch of quantum physics and demonstration of a homemade Electron Paramagnetic Resonance (EPR) spectrometer.
« Reply #501 on: July 31, 2024, 06:00:33 pm »
The link is to a paper on capacitive vs inductive iris coupling to a cavity resonator.  It describes the pros and cons of each.   My homemade EPR spectrometer is using an inductive iris.  I had tried a few different geometries including capacitive coupling.  I was using copper foil tape that I had cut the slits with a razor blade and then sandwiching it between two sections of waveguide.
https://dspace.mit.edu/bitstream/handle/1721.1/4939/RLE-TR-106-04711125.pdf?sequence=1
« Reply #502 on: August 06, 2024, 03:08:29 am »
The piston was originally a solid brass bar.  This caused problems when trying to tune the cavities resonate frequency.   I had shown an old HP adjustable short that I was originally going to use for the cavity but the screw pitch was too course and it had too much backlash.   The piston it used was a far better design.  It used finger contacts and was silver plated.     I have now changed my cavity to using a very similar piston.   The tuning is now very stable.
The iris is the next thing that I need to address.  The adjustable thumb screw is just too sloppy.   The plan is to change to using a micrometer for this as well.
Online KE5FX
    • KE5FX.COM
« Reply #503 on: August 06, 2024, 03:32:17 am »
That is one seriously awesome video.   :-+
The following users thanked this post: joeqsmith
« Reply #504 on: August 26, 2024, 01:04:26 am »
New iris with micrometer stub and finger style piston installed.  Tuning is more stable  now.
Offline coppercone2
  • √Y√... 📎
« Reply #505 on: August 27, 2024, 09:42:46 pm »
http://ro.uow.edu.au/cgi/viewcontent.cgi?article=2946&context=theses
might require a macrovna
very interesting paper, and it shows where that weird waveguide plasma jet thrust thing the Chinese made came from, and describes the history of similar apparatus. a truly enlightening paper
he gives essentially blue prints on the end
and then there is this refined document with much less detail that was made further on
https://ro.uow.edu.au/cgi/viewcontent.cgi?referer=&httpsredir=1&article=1472&context=engpapers
« Last Edit: August 27, 2024, 09:46:17 pm by coppercone2 »
« Reply #506 on: August 28, 2024, 10:54:53 am »
Next I would like to try some sample tubes actually made specifically for EPR.  I suspect with the higher purity quartz and thinner wall, it would help improve the sensitivity.
https://sp-wilmadlabglass.com/product/suprasil-epr-tubes-5mm-od/
Offline coppercone2
  • √Y√... 📎
« Reply #507 on: September 06, 2024, 04:54:22 am »
I finally tried to plate my 3d printed horn antenna with janus green B, SPS, PEG4000 copper plate.
It worked very well all things considered.
I bought some larger bottles to store the solution (media bottle)
The biggest problem is the dimensions of the conductive paint, I am still working on getting palladium strike working to plate these parts without conductive paint. The tin chloride I got is severely degraded (only 20% of it dissolved).
But I am very confident that it can be done, so long you build a fixtured plating tank and precision bend plating inserts.
I think around 8-12 GHz you can get very high quality parts made from the plating.
its actually smooth and feels like putting copper against your skin and even has the same drilling problems as copper does with nasty burrs.
Glad I decided to keep with trying to plate it instead of trying to do crazy metal casted parts. I was certain I was going to get some flaky mess but it turns out really nice if you manage it correctly.
« Last Edit: September 06, 2024, 04:58:17 am by coppercone2 »
« Reply #508 on: September 07, 2024, 05:17:50 pm »
Show some good photos of what you have.
Offline coppercone2
  • √Y√... 📎
« Reply #509 on: September 07, 2024, 07:58:04 pm »
I am waiting to do the 8-12 GHz horn because this one has a busted flange that I filled with JB weld, and its above my test frequency, it only has 3 mounting holes as a result of this. I am going to make up 2L of solution and do a better plate on a higher wave guide size that I can actually measure on VNA
1) I got a 4 inch ID copper tube segment, that is ~0.05% phosphorous, which is ideal for electroplating, compared to random scraps I use that I can form into a proper electrode
2) I got 5um polypropylene fabric coming in mail to make anode bags with
3) make up 2L of plating solution so I can plate without the antenna sitting on bottom of tank almost coming out of water (that is, it can be suspended instead of moored)
there is 100% copper coverage the black is a failure of the kool-amp silver plating to get into the crevices. all defect appear to be because of the poor paint job (it was painted with spray paint squirted into a cup and brush painted after being swirled for a while to degass it and periodically had more paint added to make it liquid, real bootleg)
If you don't do 100% job on the kool amp, it leaves silver oxide (black) on the "not fully rubbed" parts of the surface, my brillo can't get into some of the channels in the corner etc
my fresh tin chloride should come in soon so hopefully I can get away from that god damn conductive paint crap. you could sand the paint down before you work but sanding it was driving me crazy, it keeps clogging sanding sticks and you end up with a 'zoolander' situation where you have 500 clogged manicuring products in the trash
I also bought a 24/40 glass vacuum filtering funnel (non frit but with holes), fine filter disks and a 2L erlynmeyer heavy walled flask so I can filter my baths through a vacuum system using a aspirator to get crap out after a run, and hopefully for the larger tank I can use my battery powered perestalic pump to pump out the electrolyte instead of trying to pour big containers into funnels
I also have my berylium copper fixture springs (curl it up into a spring and clamp it on the object undergoing plating) and titanium tweezers to make the whole process a little cleaner. I still need to get a squirt bottle for distilled water, It got really messy when I kept trying to pour it into a normal funnel to filter it out and swapping containers etc
« Last Edit: September 07, 2024, 08:21:48 pm by coppercone2 »
Offline coppercone2
  • √Y√... 📎
« Reply #510 on: September 08, 2024, 06:29:31 am »
hmm I started to rub on it hard with a coin to "burnish" it and the surface popped off, then I basically peeled the whole horn like a heavily armored chocolate
the plating is fairly strong but the adhesion to the paint is poor :-//
I would not call it a fail, but you do need to be gentle with this method.
Basically, if you try to burnish it hard (scratch with coin), the area under the stressed area will un-glue from the paint and peel off, but I don't expect the wave-guide to fall apart if you handle it reasonably, but its sensitive to point stress, so adding force spreader beneath the flange bolts might be a good idea if you over tighten them
I did however only gently wipe down the surface with alcohol before plating, it was not de-greased properly. In some spots, the paint peeled off, granted the paint might not have been adhered great, so maybe I can say its possible to adhere the plating well enough to make the paint the weak spot, not the copper paint interface.  :-+
« Last Edit: September 08, 2024, 06:41:28 am by coppercone2 »
« Reply #511 on: September 12, 2024, 11:56:19 pm »
While we were not successful, you may have better luck:
https://www.eevblog.com/forum/rf-microwave/experimenting-with-waveguides-using-the-litevna/msg4888817/#msg4888817
I obviously gave up on the idea of plastic parts.  It's one thing to make an antenna but I think to make something like a magic T is going to be difficult.
Offline coppercone2
  • √Y√... 📎
« Reply #512 on: September 13, 2024, 12:16:11 am »
I think your current density is way too high or something, mine looked like that when I was going 6x the advised current limit because of a NASA-esque calculation fail
For burn out, I doubt you can do it. Only dissolving it (microfluidics type 3d printing) IMO can leave a copper shell really intact.
You have carrot going on, I think thiourea makes it carrot color, mine got like that when I added "tarn-x".
I need to remake my solution again, very clean, and try it at low density. I think if you get the mixture correct it should actually plate out copper colored. The problem is when you start getting high rates, it has a weird crystal structure. Its kind of like tearing a thin cut of soft styrofoam (the white one of beads). Its not gummy enough and you can actually tear it.. I think the more you stay at the minimum rate, the more ductile it is. It very much reminds me of the wrappers on chocolates when torn. I think its basically 'pre stressed' material. It would make a great wrapper for high end wines or something lol. I always wondered what metal that is, I think its just a consequence of plating. If it was like soft ductile copper, it would not unwrap.
I still did not try stirring or temperature control, I need to know what it does without control measures to see how it behaves when its 'wrong'
« Last Edit: September 13, 2024, 12:24:05 am by coppercone2 »
« Reply #513 on: September 13, 2024, 12:25:17 am »
I think you misunderstood.  The part on the left was printed copper after sinter.  The part connected to the meter was the same part prior to sinter.   Note the shrinkage.  The large part would shrink to the WR90 dimensions.  Or at least, that was the idea.
There is no current.  Rather a furnace and crucible.
Offline coppercone2
  • √Y√... 📎
« Reply #514 on: September 13, 2024, 12:33:14 am »
Oh I thought that was a thick plating and a attempt to burn out the filler like those 3d printed waxes. For getting controlled dimensions from embedded material... I don't even wanna think about it.
Offline coppercone2
  • √Y√... 📎
« Reply #516 on: October 30, 2024, 12:53:31 pm »
https://www.eevblog.com/forum/3d-printing/copper-injection-sintering-using-3d-mold/?topicseen
This is pretty much what we tried to do but with a printed part.  I can't see using their setup to injection mold something like a hybrid T for example.  Then there is the problem of shrinkage. I doubt you could get a dimensionally good part.
Offline coppercone2
  • √Y√... 📎
« Reply #517 on: October 30, 2024, 01:44:33 pm »
probobly not but these results are starting to at least look pretty nice now
I was thinking maybe round things. Squares and rectangles probably always end up messed up
« Reply #518 on: October 30, 2024, 07:05:32 pm »
I was thinking to try and experiment at higher frequencies.   There are reasons to do this with with that EPR spectrometer.  WR90 is fairly large.  I can't imagine trying to use this technique with even smaller parts.
Offline coppercone2
  • √Y√... 📎
« Reply #519 on: October 31, 2024, 03:14:46 am »
I still don't see how you are going to get ANY results, without electroless plating, for smaller frequencies. Just getting the paint to be correct on the apature prior to plating throws the dimensions out of whack. I think it might be the only good way.
but it is still interesting to see the technology got perfected that much
However, it almost seems like its a reasonable alternative to hot casting, because you don't need to pour molten metal, so safety factor goes up, like for the biconical antenna someone on the forum casted and then post machined, I can't blame anyone for not wanting to pour liquid metal and I think its a reasonable investment for lower frequency antennas.
personally though, doctors grafting skin off my ass might be preferable to wrangling with a filament printer  :-// . Using the molding machine they made looks better but I am sure it must have plenty of demons not shown on video lol
« Last Edit: October 31, 2024, 03:27:42 am by coppercone2 »
« Reply #520 on: October 31, 2024, 12:33:51 pm »
For the low frequencies I was playing with initially, that hobby brass was fine.  Even the soldered up PCBs worked well enough for the demonstrations.  None of that was plated or dimensionally good.  Surface finish was poor...  When I started to think about putting together a simple EPR system, I knew I it would be a waste of time to try and make all the components using such crude methods.
Start by sketching out how you would mold the hybid T using this method.   For something simple like a horn, I would just use copper plate.   For the X-band that coated, 3-D printed horn worked as well as the manufactured part it was modeled after.   See attached.
« Reply #521 on: January 29, 2025, 04:59:45 pm »
I had been posting about experimenting with spark gap transmitters in another thread.   Recently I attempted to utilize a waveguide with a spark gap transmitter.
https://www.eevblog.com/forum/rf-microwave/fly-swatter-ham-radio-transmitter/msg5789923/#msg5789923
This isn't anything new.   Here is some background on Jagadis Chandra Bose who was doing research with waveguides in the 1890s.
https://www.cv.nrao.edu/~demerson/bose/bose.htm
So far, my simple sources have been less than impressive.  The signal is very wideband and low intensity.   I started to do some basic calculations for a new design.  I think I just need to machine some parts and try it.
« Reply #522 on: January 30, 2025, 04:57:35 pm »
Started to work on designing / constructing my next waveguide spark-gap source.  I want to try something closer to how my other transmitters work.  Basically charge the LC, then short it.
The problem seems to be getting enough capacitance at the stub tip to make it resonate in the range I am looking for.   You can only change the stub length / diameter so much and the trimmer use to get that capacitance I suspect will have other effects.  At least on paper, it's not looking very promising.
Consider that over a hundred years ago, several king pins were experimenting in the microwave region with spark gaps.  Not much excuse for the hobbyist living in 2025 not to attempt it.  Toward the bottom they provide some of the history:
https://en.wikipedia.org/wiki/Microwave
I want to run it below 10G using WR90.  The stub length will be 5mm.   Using a stub diameter of 3.175mm, provides 1.42nH.   The LC resonance with a 0.2pF would be 9.4GHz.
The area of the tip of the stub would be 7.917mm^2.   Using a tuning stub to set the capacitance requires a 0.35mm air gap.  Roughly a 1kV breakdown.  The spark- gap would have a lower breakdown voltage.
It seems like something like this may work but it's pretty much all guess work.
« Last Edit: January 31, 2025, 01:25:44 am by joeqsmith »
« Reply #523 on: January 31, 2025, 04:09:25 am »
Spark-gap housed in the upper cavity, soldered in-place with a 9mm Luger case.   Two tuning stub located on bottom.   A bit of Kapton tape to isolate the radiator and  tuning stubs.
Measuring S21 with the LiteVNA.   System wasn't calibrated at all.  Yellow is the baseline with an open.   Red with our device inserted, port 1 driving the SHV connector.   Clearly able to see the 6GHz low frequency cutoff of the WR90.   Seems to resonate at about 8.5GHz, about 1GHz lower than my simple calcs.
« Reply #524 on: January 31, 2025, 03:21:50 pm »
Signal is still wide but is close to the 8.5GHz seen with the LteVNA.   The time is so short, it is hit an miss if the Signal Hound will detect it.  That red trace took a few minutes to accumulate that much data.
Using the real-time mode (only 27MHz or so BW), the horizontal stripes are when the SA had detected a pulse.  They are not consistent in amplitude or time.
