Hello
Here is a new power amplifier with a lot of gain for transmitters with very low output power, such as the Adalm Pluto from Analog Devices.
Data:
Frequency range: 2300...2450 MHz
Gain: over 50 dB
Small signal gain: over 53 dB
Output Power CWmode : up to 40 Watt
Bandwidth -3dB : 300 MHz ( 2200.....2500 MHz )
Signal mode: all ( with DVB reduced output power !, max. up to 8 Watt recommended )
Operating voltage: 24...30V default 28 Volt ( housing is minus )
Power consumption: max. 4 Amps at full power
Input-Output connector: SMA female
RF monitor output: SMA female ( -32dB opposite output port )
Input max. power: 1mW ( 100mW is damage power )
Amplifier size: 15cm x 10.5cm x 2.2cm
Output protected by circulator from oversized antennas VSWR
Protected against incorrect voltage reversal
More info and testreport on:
https://oe7dbh.blogspot.com/2024/01/13cm-band-high-gain-power-amplifier.html
