Author Topic: Anyone familar using a RLB with feed lines & wide band antennas?  (Read 1031 times)
Offline videobruceTopic starter
I have two runs a cable running to two discone antennas. Attached are screen saves of the scans of each with and w/o a 50 ohm load attached. The pics are labeled "up" & "low" representing the location on the mast of each antenna. All fittings are 'N'. The RLB is a Eagle RLB150N5A.
The cables are;
Unknown (unlabeled) RG8/U: 50' (labeled "upper")
Shireen RFC400: 60'  (labeled "lower")
There is also a 5' jumper w/ a lightning arrested (which I forgot they were there or I wouldn't of included that in the test).
My question is do these scans look 'normal' (acceptable) or does anyone see issues here? I was troubleshooting possible reception issues, the reason for the thread.
Re: Anyone familar using a RLB with feed lines & wide band antennas?
« Reply #1 on: June 25, 2018, 12:41:22 am »
Just to be clear, no antennas were attached. The sweeps labeled 'load' were the reference dummy load only.
I'm just interested in the feed lines themselves.
