Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
RF, Microwave, Ham Radio
FM stereo to mono (Si4712)
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: FM stereo to mono (Si4712) (Read 1283 times)
Amper
Frequent Contributor
Country:
on:
May 06, 2019, 02:15:15 pm »
Hi!
For my 10GHz transmitter Project i need a 81.5MHz reference signal and since this frequency is in the range of the Si4712 fm transmitter chip i decided to give it a go. It generates a nice signal wich then is upconverted to 10G (x128).
Sadly since it is a stereo transmitter the L&R channels then seperate out to 2*19kHz*128= 5MHz wich is far to much for the pll to run after and also far to much for the sdr to demodulate after coming from the lnb.
Is there any way of getting rid of those signals? At 19kHz i cant just use a band pass and i doubt i can turn the chip to mono somehow.
Is there some other simple way of generating the frequency i need without building an entirely new pll FM transmitter?
cheers
Logged
radiolistener
Super Contributor
Country:
Re: FM stereo to mono (Si4712)
Reply #1 on:
May 06, 2019, 03:16:33 pm »
I think you cannot do it with stereo fm modulator.
If you're need oscillator for 81.5 MHz, you can use Si5351. It allows to program any frequency from 4 kHz to 200 MHz.
https://www.aliexpress.com/item/1Pcs-DC-3V-5V-5351-Si5351A-Si5351-I2C-Clock-Generator-Breakout-Board-Module-Signal-Generator-Clock/32972854971.html
Last Edit: May 06, 2019, 03:21:21 pm by radiolistener
Logged
OwO
Super Contributor
Country:
RF Engineer.
Reply #2 on:
May 06, 2019, 03:37:23 pm »
You can disable stereo by setting the TX_COMPONENT_ENABLE register.
http://web.engr.oregonstate.edu/~traylor/ece473/data_sheets/AN332.pdf
Last Edit: May 06, 2019, 03:40:40 pm by OwO
Logged
Email: OwOwOwOwO123@outlook.com
Amper
Country:
Reply #3 on:
May 06, 2019, 04:37:15 pm »
Thank you very much! I have missed this one in the datasheet...
I will update when i have tried (probably in the next few hours or so)
Logged
Amper
Country:
Reply #4 on:
May 06, 2019, 06:22:56 pm »
Yep, it worked, though its necessary to also disable carrier:
Sadly the 10ghz is still roughly 3MHz wide and i dont know why. Ill now try building a low pass behind my output amp, we will see...
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
