Hi all,
I've bouhgt an FS1000A RF transmitter and receiver pair.
1- On most photos on the web:
- The transmitter has 2 coils, mine has only the big one! Is this normal??
- The receiver reference is XY-MK-5V, mine is MX-RM-5V. What's the difference between them?
2- I powered the 2 modules with 5V and test the DATA pin of the receiver with a voltmeter, in DC position while the data pin of the trasmitter connected to Vcc (5V) and when it's floating or connected to GND. The result: No difference (about 0V)!!!
I suppose that I must add the missing coil on the transmitter, No?
3- What are the expected results?
- In the case when the data pin of the trasmitter is connected to Vcc (5V).
- In the case when it's floating or connected to GND.
4- The SAW resonator has R315 as marking, but no thing indicating the working frequency of the receiver.
Is there any simple way to know if the modules are paired or not?
Thanks
