Author Topic: Ground is a Myth?  (Read 1040 times)
Offline metrologistTopic starter
Ground is a Myth?
« on: December 08, 2024, 02:09:14 pm »
The following users thanked this post: Geoff-AU
Offline mtwieg
Re: Ground is a Myth?
« Reply #1 on: December 09, 2024, 02:26:00 pm »
The true ground is.... in your heart.
Offline coppice
« Reply #2 on: December 09, 2024, 02:49:23 pm »
I know ground plane is not a myth. I had to fix the design of a control system for an aircraft, as it was causing a lot of vibration and wear and tear in a gear box. I can tell you there was a lot of ground plane when we opened up those gearboxes.
The following users thanked this post: hendorog
