Sure but how show I find someone who jamm the CB Band when the Apartment buildings are in the Grass.
You walk around with
your portable radio with a portable antenna attached (e.g. a whip, rubber duck, piece of wire etc., forget your rooftop antenna) and take measurements of the signal strength.
If you have a directional antenna (e.g. a handheld loop - easy to DIY), you can take direction measurements from two (better more) places and draw lines on a map to see where they intersect - that's where your source of interference is. Directional antenna is preferable, because it is much more accurate and faster method than homing on the source using only the noise intensity.
Not sure what is so difficult to understand on this.
If your portable radio is unable to handle this, get an RTL-SDR dongle, USB OTG cable and plug it into your phone/tablet. There is software for it for Android too.
