I am far from microwave expert, in fact this is the first module I popped open. Here are some pictures of the module. It is labeled as IFI, but it looks very similar to AMP1124 from EAC, which would explain the transistors.
The symptom is that there is no output and no significant current draw. My current plan is to turn it on and probe with a high impedance scope probe around the input section. But having never opened one of these I wonder if there is a danger of feedback with cover open, so maybe I should screw down the cover so it covers the output section. Also can check the bias voltages, but first I need to learn what they are supposed to be...
