Author Topic: ROHDE & SCHWARZ SMDU and SMDU Z1 test set owners!  (Read 1752 times)
Offline py1dkw@yahoo.comTopic starter
  • Country: br
    • Electronics Equipment Maintenance and Writer
« on: April 29, 2024, 12:51:33 am »
I had worked with this nice test set from 1984 to 1999 and now I could get the same unit here in Brazil. The R & S Support gave the available manuals, but my SMDU is changing its frequency in RF generator mode fast, but only in the lower band, the upper bands are ok and not out of lock. Does any owner of SMDU knows where I could start looking for the defective part? I had the SMDU Z1 unit restored and works fine. Many thanks, 73s Sam Rocha, PY1 DKW
  • Country: br
Re: ROHDE & SCHWARZ SMDU and SMDU Z1 test set owners!
« Reply #1 on: May 22, 2024, 09:29:02 pm »
Does anybody knows where to find the coaxial relay used in Rohde Scwharz SMDU, SMDU Z1, ESU2 and many other equipment? I noticed they can be disassembled and cleaned with Freon.
Offline Harry_22
  • Country: hn
« Reply #2 on: May 24, 2024, 08:31:21 pm »
Hi!
Could you possibly attach the photos of the relay.
