I'm looking to source a body-mounted "puck" type antenna for use at 433.92MHz. These are often used for M2M use, about 50-80mm diameter, and look like this:
Trouble is, most of them are rubbish! They are more often than not a helical spring wound to be resonant, but drift massively and generally perform about the same as a wet piece of string. I know that cramming a 70cm wavelength antenna into such a small form factor is a compromise in the extreme, but these really are dire. Here's one I cracked open:
This one is sold as a true omnidirectional. My ass!
I've only found one to date that really works, which is made by Linx. But that's now obsolete which is a real shame as it looks like some effort has been put into the design, and as I say it actually works and is fit for purpose.
So does anyone here use such a thing? This is for a commercial offering so not interested in DIY. Whip, stubby, rubber duck not suitable because of vandalism concerns. From the generally-availiable brands (from Mouser, Digikey etc) I've so far eliminated RF Solutions, Siretta, Taoglas.
