The ADF synths were always my go-to when needing a signal source, but the old Hittite (HMC833 family) did deliver better phase noise. Then I disovered the LMX2594
The early versions of the 2594EVM did include a good TCXO100 MHz reference, but sadly this is missing on the one sold now. Instead they have an integrated clock source that does lack a bit. Using a high performance 10 MHz reference, lock one LMX2594 and have this output 100 (or 200) MHz as a reference to the main synth should give really good performance and and also by adjusting values, reduce spurs from the main loop.
The number of registers (112!) can be a bit overwhelming when trying the LMX2594, but by using the TI software you see exactly what is written, where... and by using this information one can easily see what registers that are affected when changing settings.
Has anybody written a software driver for the LMX2594 for generic SPI?
I have made a tiny board with an 2594 that can be controlled by TI Software
and the TI USB I/F board. When I had the board working, the chip was no longer
available, so there was no real reason to follow that further. Now the availability
has improved.
I'm working on a wide band down converter to convert everything up to
12 or 20 GHz down to 5...28 MHz. There is an ADF4002 to lock an ECS-2522
100 MHz oven (Digikey) to an external10 MHz ref.
Abracon 100 MHz non-ovenized should also work.
The ADF4002 is in the middle/left, the oven right to it. Since it delivers
3V3 CMOS, I simply buffer it with 2* LVC125, filter out the 300 MHz harmonic,
SKY MMIC for same gain & squaring, two 900 MHz SAW filters à €1.50 to clean up,
1 more MMIC and the LO for the 2nd down conversion is done.
On the right side is the home for an LMX2594/95. It currently gets its clock from
the 100 MHz oven. 900 MHz from LO2 should be possible, too, but I did not want too
many unknowns right from the start.
The LMX is the 1st LO. There is a low and a high band, nervous DC.. 3GHz and
3 GHz to 12 or 20, depending on LMX and available mixer. I wanted a mixer
to 20 GHz with built in driver, and you guess, it is unavailable now. The alternative
is a Hittite HMC-220, which results in a hole from 3-5 GHz and ends at 12GHz. :-(
The 1st IF is 900..928 MHz with the same SAW filters.
On the top right is a LT3045 regulator for the 3V3 with enough power for the oven.
The idea is to use 2 of these boards to extend my Timepod from 30 MHz to
wideband with cross correlation. Should also work for ham radio and deep space
network with the right preamps/filters.
I'm still soldering, the 900 MHz LO2 works already. :-)
The board is 4 layer FR4 from JLCPCB. for $5. 10*9 cm. I have 5 of them.
It will be open source. Comments / proposals welcome.
Gerhard
