I have LOTS of nice RF relays. The problem is, they are all latched type and spec sheet prohibits continuously supplying current to the coil.
Say I have two push buttons and give a short pulse to one terminal. One would assume relay switched to the corresponding port. But how do you know for sure? Relay could get stuck, coil can burn out, all kinds of things could happen.
I know there are latched type relays with separate contact just for this purpose. That's not what I have. I have 1 sma port for input, 2 sma ports for output, and 3 DC pins. Ground, port A enable, and port B enable. I am thinking of creating a switching matrix. I could, perhaps pass DC via DC block and coil, and pick up at output the same way, but that's a lot of work with possible degradation of signal.
My tired brain can't come up with any good solution. I am hoping someone has an answer.
Anyone?
By the way, my use case is to switch between different GPS antenna, so frequency range is about 1.5GHz. To begin, will have 4 ports out, 1 port in. That means signal coming in are almost identical and selection will stay for a while. I need some kind of an indicator.
Taka
